Hose length for the DRM brake duct kit?
How long are the hose pieces to go from the DRM ducts to the spindle? I need to replace the hoses on my car so I wanted to know how much hose to order.
Thanks,
Matt
Thanks,
Matt
I used 24" on each side - that gives enough tubing to allow for flex when turning or at full suspension travel and to tie it down to the A arm. If you are ordering, I would get 5 feet - a little too much is much better than getting 6" too short for your application.
A mounting note - the closer to the centerline of the axle the better.
Also - SCAT hose works well and is cheap. It is springy which is good for keeping the hose in place during tight turns.
