Full Face Helmets Vs Factory Air Bags
Received 8,917 Likes
The BMW Club chapter that I instruct with held an instructor's seminar over the weekend. Joe Marko of HMS Motorsports did the presentation on track safety. He mentioned there has been some helmet/air bag deployment testing done at Delphi. The tests showed there is no difference between an open face helmet and a full face helmet with its visor closed/locked or removed when an air bag deploys. The air bag doesn't get caught under the chin of the full face helmet. However, if you have the visor partially open instead of fully down and locked into place the air bag will catch the visor and throw your helmet backwards. Sun shields/visors over the eye port on open face and full face helmets will do the same thing so they need to be removed.
Bill
Bill
Bill
But a question from a new guy doing HPDE's, is removing the visor at the top of the opening "modifying" the helmet? And is this something that could cause any issues with the governing body of an event?
Or is it a personal prefference thing and I am over thinking it?
St. Jude Donor '05-'08
Thanks for the info!!
or even bolts, as in Rubins a few years ago.
Bill
I doubt it would be considered modifying the helmet. The so called peak visors are just snapped onto the helmet and are a sun shield. The NASCAR style bill that you see on a lot of open face helmets is held on with 3 or 4 snaps. Joe had several of the Stilo helmets that he sells at the seminar. They have an optional peak visor to block the sun that can be added to a full face helmet so you can get both styles of visors on one helmet. I don't think any other manufacturer offers that option. I have to say those were Cadillac helmets. They had noise reducing ear muffs that reduced sounds from outside the helmet and had integrated radio wiring so you don't have wires running around inside the helmet.
Bill
Bill
Ok.. and just to be very clear here is a pic of the things I am talking about removing just to make sure they are what you are saying.
I don't have the red arrow part, but I do have the yellow arrow part. So you are saying remove both of these?
And Bill, sorry for all the questions, and thank you for taking the time to pass the info along to begin with and to answer my questions
Bill, thanks for the information...there has been a lot of discussion in PCA about the airbag/full face helmet thing with the PCA regions I instruct for, and we also have had no resolution regarding it...I run with my full face visor down, and never thought the airbag would grab the bottom of my helmet, but some folks were convinced it would...
Good Info!
Good Info!
Good Info!
Good Info!
Bill
Any thing that looks like this should be either fully closed and locked or completely removed.
Anything that looks like this should be removed.
Bill
I can see it being possible that as the driver's head moves forward and contacts the bag the visor could cause the neck to bend (as if the driver were "looking up"), but certainly not forcefully throw the person's head backward.
Did they show video of this situation? In general, a properly belted occupant should have little to no actual contact with the bag unless the seat is very far forward.
I'm having a hard time envisioning this phenomenon. The airbag will be fully deployed long before the driver's head gets there. The bag inflates in a matter of milliseconds with the intent to "catch' the driver in a fully inflated bag and decelarate the head and neck slowly as air escapes from the vent in the back of the airbag. The bag will not come out and smash into your helmet and throw you back.
If I remember what Joe said correctly in an impact without an air bag a person's body and belts will stretch about a foot forward. The looser the lap belt the further forward they go.
Then there is the air bag itself. Unless you happen to fasten the stock seat belts while you have a harness on the air bag system will think it is dealing with an unbelted person and deploy at full force. With your body moving forward over the lap belt (which is also stretching) your head is going down into the air bag thus the bag can catch on an obtrusion on the front of the helmet.
You can call Joe at HMS and discuss this with him if you want. He is the expert. I am not even close to being an expert and all I am doing is just trying to relate to you what he has said. It is always better to get the information from the horse's mouth than an intermediary on a subject that is as important as this.
Bill
CI 4-5-6-7 Veteran
From the picture I am not sure if there is a clear face shield visor underneath. If there is it should be completely closed and locked so nothing can come in through the face port while all of the other stuff should be taken off. If you want the face shield open then it should be removed as well. A full face helmet with an open face port and an open face helmet react the same way to the air bag.
Bill
Bill
Crystal clear.. Thanks!
Bill
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Great information guys. I usually run with my face sheild up because of the temps down here in the Houston area during the summer. I won't be doing that any more. I never really gave that issue any thought at all. Face shield down from now on!
