Stock 18's on all 4 corners tire question
I'm getting ready to go to a BBK on my 02z06, I have 2 sets of 18 rear z06 wheels. I want to run Nitto 555II 305/35/18 on all four corners. I have check the sizing and other than a little rubbing on the front at full lock the fit is good. Will this set up cause me any problem with my "nanny's"?
I have check the spacing and I will need 1/8" spacers so I think I'm ok there however I run in "compitition mode" and I was wondering if the identical sized tires both front and back will cause the "nanny's to trigger"?
You'll have to turn the nannies off to run a square set up. Since the stock configuration is a 17/18 stagger the computer looks for a difference in rotational speed between the front and back tires. With a square set up there is no difference and the computer will think there is a loss of traction.
On my old Z06 I ran 17x11 GrandSport wheels with 315s all around. If left in comp mode, once in awhile it'd trigger "SERVICE ACTIVE HANDLING, SERVICE ABS, SERVICE TRACTION CONTROL", but I'd reset the code on the back straight at VIR. It only happened a few times.
On my current TTA car I run 275/35/18 or 255/35/18 all around on stock rear wheels and have no issues, but I do run with everything off.
I have been running Pirelli slick 305/680/18 on all fours, really tall but I get them in good shape from a porsche team 100.00 each and they feel pretty good, would rather have proper sizes but got to run what you can get sometimes. all nannies off, no trouble
Does anyone have experience running NT555RII's in a 305/35/18 Rear & 285/35/18 Front setup on stock rear C5 Z06 Wheels, with all nannies on ?
Looks to be a .5" stagger Front to Rear
Ed
Ed
I ran at VIR this past friday in my 02z for the first time with the exact setup your refering to...........sorry to say I only got about 20-30 total minutes on the track due to a oil psi issue however I had no issues with nannys on or off.
