T1 bars end links?
Old 04-22-2011, 08:35 PM
bsalie99
bsalie99's Avatar
Default T1 bars end links?
I just picked up a set of T1 bars for my C5 Z06. They did not come with endlinks. Can I use my stock 2002 Z06 endlinks?
thanks
Old 04-22-2011, 08:52 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
yes, but if you are going to T1 bars, you should really corner balance your car which requires adjustable end links.
Old 04-22-2011, 10:22 PM
bsalie99
bsalie99's Avatar
I have the full set of T1 bars and an ADJ Pfadt rear bar( with links)
What would be better to use for autocross?
And where can I get the endlinks for the T1 bars
Old 04-22-2011, 10:25 PM
sperkins
sperkins's Avatar
Yep - or at least adjust them for preload.
Old 04-22-2011, 10:29 PM
RogerT
RogerT's Avatar
Default Adjustable Links
I think you can get adjustable end links from Vette Brakes & Products.
Roger T : )
Old 04-23-2011, 06:55 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
LG sells a good adjustable end link for the T1 bars.
http://www.lgmotorsports.com/catalog...1a2851b7a2020e
Old 04-23-2011, 08:26 AM
sothpaw2
sothpaw2's Avatar
Call Pfadt. I really like the endlinks supplied with my JO bars. Quiet and adjustable via jam nut from the center. Noise & corrosionresistence are the big issues w/endlinks.
On adjustable vs stock: some here have managed to achieve zero preload with stock links. You really must have the bars installed with zero preload. If there are preloaded, they will tear up end links and rod ends and I think handling may also be affected. I went with adjustables simply to ensure that I can get zero preload with the new bars.
Shops have told me that cornerweighting a leaf spring car is a waste...I gather it's hard to do. If you have coilovers I'd definitely get adjustable links and then cornerweight it.
Old 04-23-2011, 09:50 AM
sperkins
sperkins's Avatar
That makes no sense at all. Whoever told you that must watch too much Top Gear.
Old 04-23-2011, 03:40 PM
Racer86
Racer86's Avatar
Total BS ,,the corner weights can be adjusted on the corvette with "leaf" springs. You use the lowering bolts. As the spring is mounted at 2 points, each wheel corner weight can be adjusted.
Get a new shop
To T1 bars end links?
Quick Reply: T1 bars end links?
