If you want to STOP.......
....order the right parts!
Gary @ Hardbar's AP T1 #8350 4piston Caliper
DRM/Coleman 2pc slotted 14" rotors
ATE Super Blue Brake Fluid
Quantum Motorsports Z06/GS Competition Brake Cooling Kit
Rob Willis
2011 Velocity Yellow GS Coupe, M6, 1LT, Dry-Sump, Comp Gray Rims
LG Carbon Fiber "ZR1" Splitter & Sideskirts, Front Tow-Hook, Black Alcantara Steering Wheel & Shift **** w/ Yellow Stitching, VY "ZR1" Rear Spoiler
Rob Willis
If you haven't already used it, I'd say to dump the ATE blue. Not because its a bad fluid, but because it stains everything blue.
I wish I never used the blue for that reason alone.
I was actually considering just biting the bullet and getting the Castrol SRF. How hard is it to tell when you get the new stuff thru the system? DOn't want to bleeding crap loads of liquid gold down the drain!
I've used it before, in my 2007. DOn't like that it stains everything either...
Don't hammer a wood screw in the crown molding get some SRF. Figure the cost per oz. not per container then figure it works better and last at least twice as long. Then see what it cost.
