Michelin Sport CUP - 325 vs 345 rears
Old 04-27-2011, 01:42 PM
CanadianVetster
CanadianVetster's Avatar
Default Michelin Sport CUP - 325 vs 345 rears
stock Z06 - tires for track days
OEM rims - 18/19
Is the 345 too much tire for a sock Z06 - pro/con's
Is the 325 enough tire.
Also what size would you run on the front with the 325 or the 345's
Old 04-27-2011, 03:12 PM
AU N EGL
AU N EGL's Avatar
Look at the weight of each tire. I bet the 345s are quite a bit heavier then the 325s.
the wider the tire the longer it takes to get heat into it too.
Old 04-27-2011, 04:00 PM
Blurr
Blurr's Avatar
OEM rims - 18/19
If you plan to do track days you might want to consider going with 18" wheels all around, better selecton and less expensive tires.
When I ran with sport cups I used 345's on the rear and 295's on the front as AU N EGL points out, it will take time to get heat into the rears...trust me I know this all to well.
To Michelin Sport CUP - 325 vs 345 rears
Quick Reply: Michelin Sport CUP - 325 vs 345 rears
