Tie rod / ball joint question
I am in the process of changing the transverse springs and shocks in my car. I purchased the GM / Kent Moore tool for seperating the tie rod ball joint, and it worked great. My question is regarding torquing on reassembly....The manual says to do a first pass torque at 15 ft/lbs, second pass of 160 degrees, then a third pass torque of 45 ft/lbs. What is the logic behind this sequence? Is this how everyone does it?
Thanks for the help,
Charley
Charley
I think it has to do with the taper on the shaft. Too much torque will expand the hole in the upright.
15 ft-lb probably takes all the clearance out of the joint.
160 degrees (Turn-of-the-nut method) give a precise load that is not affected by lube etc. on the stud.
33 ft-lb. is a double check. (Service manual says 45 Nm)
I just did mine yesterday.
I just double checked my manual, and confirmed that the third pass for the C6 (in the 2008 manual) is 45 ft lbs (60Nm). Is the torque you refferenced for a C5 or C4?
Thanks again for the help.
Charley
that is actually one place I don't torque, simply because the load is in sheer, not in tension. Torque shouldn't effect the actual strength of the joint.
I just snug them up
I just snug them up
