Another ball joint question
I was working on my suspension over the weekend (changing the shocks and transverse leaf springs. I this process I disconnected one of the ball joints on the arm going to the rack and pinion. Something just didn't feel right when I was re-torqueing. If felt like there was some stretching of the tie rod. Last night while I was reflecting back on the procedure I started wondering if I inadvertently used 45 ft/lbs for the final pass (like on the rear tie rod ball joints) vs. 33 ft/lbs. Today I disassembled the ball joint again, and visually it looks fine. I re-torqued with no issues.
My question is....If I did mis-torque them to 45 ft/lbs do you think this warrants replacement? A failure of this part would not be fun.
Thanks for the help,
Charley
Charley
Don't waste your time or money replacing that joint. As long as the boot is solid and the ball is tight in the socket you will be fine. An extra 10 ftlbs of torque on that large of a bolt is not a problem.
