My XYZ Brake Report to date
I know there was some interest from guys in the XYZ brake system.
I put them on my 06 track car and have run 4 days on them. Should have been 10 but due to early clutch problems and one day rained out, I did not get the time on them I had hoped at this point.
My thoughts so far are:
Customer Service
Original fitment
Brake Pads
Rotors 14" 2 piece floating rotors on all corners.
Brake Lines
Calipers
With all the work I have done to the car over the Winter, I am just getting up to speed with driving and will be standing on them more as I go.
So far I have to say I am very pleased with them overall. If I was not, I would say just that.
Customer Service
- Very good so far
Original fitment
- Had to have the hats machined out a few thousanths when I received them as they were just a bit too tight and would not seat exactly right. I think they have solved this problem since then.
- I had them machined out and Jon paid for it
- Had some shim issues on the install but that all worked out and now no problems with fitment whatsoever.
I was initially pretty frustrated with the install but I get frustrated easily. In the end, it all worked out.
Brake Pads
- the pads that came with them were "Race" pads. Not exactly sure how this would compare to a Hawk or Carbotech compound but they have been very good at stopping, very consistant throughout each session and the wear has been less than expected. I also have some Hawk DTC-70s to put on next.
- Pad wear has been essentially even across all 4 brakes and each side.
Pedal feel has decreased slightly from the inital wedding d*%& feel but that is pretty much universal with brakes I would think. Still very good brake pedal feel.
I would say only about 20% wear so far.
- Even wear so far with only a very few, minor spider cracks on each one.
- I am expecting to get quite a few events out of the rotors as compared to my NAPA rotors which sometimes did not last a full session.
Brake Lines
- they came with new brake lines and all is well with that aspect of it.
Calipers
- No obvious signs of issues. I have taken them off and completely cleaned and inspected them after each event.
- the only thing I have noticed is a very slight fluid accumulation around the bleed screw. I cleaned them up and tightened them just a bit more but essentially no issue.
- The proof will be in how they last but so far, great.
