C4 manual steering ????
Old 05-23-2011, 05:32 PM
The Bus
The Bus's Avatar
Default C4 manual steering ????
Did I read somewhere that a C4 can become manual steering with very little work?? Without changing out the rack. I've done that but never again. I was in a race on Sat and after about 10 laps the hose or pump failed. RATS Second in my class and 4th overall. %$#$()_)(*&^%$#@#$%^&*()_)(8
Old 05-23-2011, 08:36 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
There is a post in the C4 tech section on manual racks.
IIRC it was a pricey proposition
Old 05-25-2011, 10:45 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
DRM sells a stainless steel high pressure line.
You running a cooler? some cars didn't have them
Old 05-26-2011, 01:35 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,929 Likes on 5,333 Posts
Having had a hose fail on my 86 during an autocross I can imagine how heavy the steering felt when yours let go. I suspect that a manual rack would be considerably slower than a power rack so you would be able to steer the car for more than a minute or two.
Are you using the Turn 1 pump and hose setup on your C4? A buddy had continual hose failures on his 94 until he went with the complete Turn 1 pump and hose setup.
Bill
Old 05-26-2011, 06:28 PM
The Bus
The Bus's Avatar
actually this is the first failure after 7 years of racing/track days.
To C4 manual steering ????
Quick Reply: C4 manual steering ????
