where is the squeek coming from??
St. Jude Donor '06
changed the tensioner,the idler pullery,the belt,,still squalling like a little girl...how to tell if it's the water pump....'98 C-5 six speed....
Johnny
Johnny
One simple thing you can do while eliminating sources is to remove the oil fill cap while the squeek is happening. If the squeeking stops it is vacuum related and air is getting past your seals.
I had an chirp I chased to no avail on my old Z06. I replaced the tensioner and both idlers. A buddy told me to try a Gatorback belt and as a last ditch effort I did.... and the car shut up. Dunno why in this particular case that worked, but I was going nuts with a fancy (at the time) car that chirped like a bird.
