New setup - 17" C5Z wheels with 275/40/17
This is the setup I'm looking at using on my '00 vert for autocross events. I'm new to the game so please be nice.... I want to run all four the same to be able to rotate them around to get more tire life.
Tires are possibly Nitto NT05. Any advice?
Will the 'square' setup affect my Active Handling and ABS?
Is there a better setup suggestion?
Thanks,
-KOZ
Thanks,
-KOZ
I run 275/40/17 square on my C5Z for track days and it works well. It all depends on your car setup and driving style (how much oversteer/understeer you have).
It won't affect ABS but may affect TC/AH. I would recomend turning off TC/AH for auto-x. You want to be sliding the car to a small degree.
I ran 4 17x9.5 Z06 wheels with a 275 for a bit before moving to 4 18x10.5 Z06 wheels. They are very very light, but I felt the car to be a bit squirrelly comout out of turns. The lower profile tire used with the 18" wheel just felt better.
However, for consumables cost and weight it's hard to beat the 17x9.5 setup. If I were just doing HPDEs that's what I'd run for sure.
Received 8,926 Likes
It will not bother the AH but may bother TC. AH uses steering, yaw and g sensor inputs to determine when to activate so what the wheels are doing isn't as important to it as TC.
Bill
Bill
Thanks,
-KOZ
Thanks,
-KOZ
I would expect you to have trouble putting power down coming out of turns with little 275's on the rear. I have run A6 335's (rear) and can break them loose all day long if I get on the gas too quick.
TC/AH is looking for a .7 inch f/r differential (tire height). There is some tolerance, but any time I have got close to the same height f/r my nanny comes on. This can be overridden by turning tc/ah off.
I am a fan of the square set-up, I run that. Being able to rotate tires front to back can really help with "wear" issues. Turn off the AH/TC anyway. I do like the 18" wheels and lower sidewalls for my driving style, but the 275-40-17's are a bargin and very effective as well.
