DEI Cool Tape for joint boots
Hello folks,
Following many recommendations from this forum, I am about to order some DEI Cool Tape to wrap my lower ball joint and outer tie rod ends. Do I need the 1 3/8 width:
http://www.summitracing.com/parts/DEI-010408/
Or the 2in width?
http://www.summitracing.com/parts/DEI-010413/
2in is significantly more expensive, so I'd like to get away with the 1 3/8 if possible.
Thanks!
Or the 2in width?
Thanks!
I have both... I honestly can't remember which I used.. but here's a picture for reference. I'm thinking 2" is what works best.
EDIT - Those links you posted are for a 15' roll of 1 3/8" and a 60' roll of 2", that's why the 2" is so much more expensive.
I was thinking the narrow tape will conform better to the odd shape being wrapped. I have also used regular alum tape which is almost free.
Not sure it makes much difference as long as you do something.
Looking At the pic, I noticed a plastic zip tie. I would recommend a stainless steel zip or safety wire.
I also used a fire resistant tape with a layer of heavy aluminum foil held in place with a wire ties over all of the boots. No problems with the plastic wire ties melting.
Jim
Jim
