What clutch fluid do you recommend?
Old 06-02-2011, 12:32 PM
Charley Hoyt
Charley Hoyt's Avatar
Default What clutch fluid do you recommend?
Thanks.
Old 06-02-2011, 12:44 PM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
SRF
Old 06-02-2011, 01:17 PM
Charley Hoyt
Originally Posted by WNeal
SRF
Thanks, I didn't know that you could use that for the clutch....Can any DOT 4 brake fluid be used??
Old 06-02-2011, 01:24 PM
WNeal
WNeal's Avatar
"Slower Azz Dog"
Not exactly sure on any brake fluid but I have used SRF in my race car for several years and would not use anything else.
Old 06-02-2011, 01:28 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Clutch fluid = brake fluid
Power steering fluid = trans fluid
Old 06-02-2011, 01:29 PM
WICKEDFRC
WICKEDFRC's Avatar
Received 1,652 Likes on 738 Posts
What is the primary difference between SRF and Dot 3 / Dot 4? Boiling points? Shift feel?
Old 06-02-2011, 01:35 PM
jcosta79
jcosta79's Avatar
That, and a whole bunch of $$$$.
Old 06-02-2011, 01:39 PM
gumby4mayor
gumby4mayor's Avatar
Just go get some brakebest dot4. you can get the big bottle for $7 at o'reilly.
Old 06-02-2011, 02:22 PM
RX-Ben
RX-Ben's Avatar
RBF 600.
No worries about pedal going soft.
Old 06-02-2011, 02:54 PM
95jersey
95jersey's Avatar
You can use an expensive Motul, but it is not required. The clutch fluid will never get as hot as the brake fluid.
With that said I use it in my clutch simply because I buy motul by the case and it is only a couple ounces (if that).
What is more important, is that you change it out regularly no matter what brand you use, but any Dot4 brake fluid is fine, just NO SYNTHETICS.
Old 06-02-2011, 04:05 PM
WNeal
WNeal's Avatar
"Slower Azz Dog"
There are a couple of folks if not more who have said that ATF in the PS pump will degrade the seals.
Not sure but I know mine did not last long after putting that in.
I am getting ready to put my 4th PS pump in the car and I am just going to put regular old PS fluid in it. Also now have a 25% underdrive pulley.
Had Royal Purple in the last one and the only problem was I could not definetly tell if was RP PS fluid or RP motor oil when the leak started.
Old 06-02-2011, 04:06 PM
WNeal
WNeal's Avatar
"Slower Azz Dog"
Indeed
Old 06-02-2011, 04:33 PM
lbs90ZR
lbs90ZR's Avatar
I just found a brake boiling point tester, could be interesting to see how long the different fluids last. Couldn't find a price on it though.
http://hsy.com.au/techinfo/ATE_Brake...er_FBT_320.pdf
Old 06-02-2011, 06:20 PM
Armycop
Armycop's Avatar
Take lotsa pictures so those of us who will be doing this can follow along!
okaythanks!
Old 06-02-2011, 07:20 PM
TS Motorsport
TS Motorsport's Avatar
I don't want to go off topic but we use amsoil synthetic in our PS and the seals have been fine so far.
As far as clutch fluid we use ATE type 200. It doesn't contain silicone so it will not damage the system.
Old 06-02-2011, 09:58 PM
crainholio
crainholio's Avatar
Manual trans fluid = auto trans fluid
Old 06-02-2011, 10:00 PM
crainholio
crainholio's Avatar
I ran Valvoline Max-Life PS fluid in mine last week at Pocono and had no boiling, seems to be good stuff.
To What clutch fluid do you recommend?
Old 06-04-2011, 10:22 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
I use this in both my brakes and clutch:
AMSOIL Series 600 DOT 4 Racing Brake Fluid (Product Code BF4SN)
Dry Boiling Point - 580F, Wet Boiling Point - 410F
And FYI, AMSOIL makes a synthetic power steering fluid, so no need to use an ATF.
AMSOIL Synthetic Power Steering Fluid (Product Code PSFCN)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 06-04-2011, 09:12 PM
rustyguns
rustyguns's Avatar
Castrol SRF ..Unbeatable!
Old 06-05-2011, 03:21 PM
Painrace
Painrace's Avatar
I agree. If you don't want any issues use SRF in brakes and clutch!
Jim
Quick Reply: What clutch fluid do you recommend?
