Torque tube gone bad.
Old 06-02-2011, 07:23 PM
mountainbiker2
mountainbiker2's Avatar
Default Torque tube gone bad.
On my way home from racing 12 autocross laps, I noticed my car felt kind of funny. Like free play between on the brakes, then back on the gas. This is what A&A Corvette found.
Steve A.
Old 06-02-2011, 07:46 PM
Pfadt Racing
Pfadt Racing's Avatar
Oof. Looks like you might have some trouble transitioning from on to off throttle with that kind of damage!
Now might be a good time to think about a carbon fiber drive shaft. Here is a link to some more info on the stronger, lighter, and more durable carbon fiber piece that eliminates the guibos all together: Pfadt Racing Carbon Fiber Drive Shaft
Old 06-02-2011, 07:59 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
typical fuzzy mess!
Old 06-02-2011, 08:17 PM
mcar00
mcar00's Avatar
Never really thought about this before, but does anyone believe that due to being in lower gears in an autocross (and maybe more abrupt throttle/brake/throttle transitions) that it could be harder on the car than road racing?
Old 06-02-2011, 08:26 PM
mgarfias
mgarfias's Avatar
Not on the driveshaft I don't think so. Its before the transmission, so it has the same torque applied in every gear. Vs say an fbody where the driveshaft sees a lot more torque in 1st than in 5th.
Old 06-02-2011, 09:49 PM
CHJ In Virginia
CHJ In Virginia's Avatar
WOW - you really got lucky to make it back without a catastrophic failure. That is about the worst mess I have seen on a torque tube.
Old 06-03-2011, 12:15 AM
rustyguns
rustyguns's Avatar
Steve A.
mine looked exactly the same...plus i broke a few bolts.. i felt it too and caught it before it killed the tube. this is normal, those rubber bushings are only good for 5 years tops. bought two BMW ones and popped it back together.
(was a bit tougher than that )
thanks to all that helped!
Old 06-03-2011, 01:21 AM
travisnd
travisnd's Avatar
Ugh that looks like fun... glad it didn't cause more collateral damage than that.
Old 06-03-2011, 09:47 AM
redtopz
redtopz's Avatar
Nice Steve! I think you can rebuild those couplers with a little glue and lots of patience .
Old 06-03-2011, 10:29 AM
Charley Hoyt
Charley Hoyt's Avatar
Looks bad...but,Knowing you, I bet you still won the race.
Old 06-03-2011, 12:25 PM
froggy47
froggy47's Avatar
I would think yes. In autox you usually stay in 2nd gear with a lot of full throttle/closed throttle torque on the shaft from both ends, engine torque and drag from the low 2nd gear.
I think there is less torque applied in the higher gears of track. But it's probably mostly to do with how many "cycles" the shaft goes thru.
Old 06-03-2011, 05:47 PM
John Shiels
I drove to VIR 13-14 hours each way and the same thing happen to me. I missed most of the two days I went for.
Second time I went to VIR the clutch went after a day.
To Torque tube gone bad.
Quick Reply: Torque tube gone bad.
