Instructor communications devices?
Old 06-04-2011, 02:33 AM
morris
morris's Avatar
Default Instructor communications devices?
What are the communications devices called that are used for in car communications between an instructor and student? Who has them etc?
Old 06-04-2011, 05:58 AM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
Try a search for Chatterbox. There are several vendors for it.
Old 06-04-2011, 07:38 AM
JDIllon
JDIllon's Avatar
Discovery Parts! call Ron. http://www.discoveryparts.com/cgi-bi...communications JD
Old 06-04-2011, 09:56 AM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Originally Posted by JDIllon
Ask for the NASA-SE 10% off!
Old 06-04-2011, 10:04 AM
morris
morris's Avatar
Thanks everyone!
Old 06-04-2011, 10:56 AM
R Mackow
R Mackow's Avatar
Try OG Racing. I just bought the complete set from them, while others only had pieces.
Old 06-04-2011, 12:50 PM
Bill32
Bill32's Avatar
Yep, Chatterbox, HJC-50.
I've been using them for 12 years.
Note that you should pick the headsets that work for you depending on weither you want to permanetly mount yours in your helmit.
And the "student headset" is what you want for your driver.
The only thing with the Charretbox is that the unit has to be in the "off" position when charging it. If the unit is on, it won't charge and you'll be pissed when you get to the track (ask me how I know).
To Instructor communications devices?
Quick Reply: Instructor communications devices?
