DrySump Oil Change - Tip
About as simple and cheap a solution as it gets. No draining...
Transfer pump $5.99
http://www.harborfreight.com/multi-u...ump-66418.html
24" stainless .5" OD tubing $11.98
http://www.onlinemetals.com/merchant...=312&top_cat=1
10 Minutes, no jacking, no mess.
Transfer pump $5.99
I use one of those on my Jetski. It's a Honda with a 4-stroke fuel injected 1300 cc 4-cylinder. Has a dry sump. Have to suck the oil from the oil fill and then a special port on the rear of the engine.
You can also use that to fill your transmission and differential.
