Alignment question ride height AFTER alignment
Yes I know I did it backwards, but here is the question.
All the adjustment was on the RR increasing RR height which basically brought it close to LR height and also lowered LF height, all as I expected & desired.
Raised (shorten bolt) about 6 threads on the RR I won't bother with all the mm details, about a 3/8 inch rake now.
I LOST neg camber in the rear from -1.9 both sides to -1.5 both sides. Front no change.
I expected that too, no worries.
Question is which way did my rear toe change? I may not have time to string the car before the weekend events.
I had 1/4 total toe in.
If I got more toe in it's all good but if the camber change made rear toe move out, not so good.
Thanks, please no guesses, only post if you know alignment.
What you are asking for is a guess. Take a straight edge to both rear wheels and measure toe... Then shoot a laser from the rear wheels to the front to check thrust.
You could have been almost done with it by now. =)
you need to measure it....use my guide, a straight edge and a tape measure.
http://www.davidfarmerstuff.com/align.pdf
Takes me less than 1 minute to check toe.....
OK guys, that looks easy enough, but I don't agree that "it's a guess".
Reduced neg camber (talking rear for now) either toes in the rear or toes out the rear, can't be both and it can't do it one way on Monday & the other on Tuesday.
But I will post how it comes out, too late now, wife made a nice dinner & a little Cabernet (for the heart).
I set up the strings, because I was concerned that if I switched to a different measuring system I might introduce measuring (operator) error.
I'm getting faster every time I do it.
Wish my eyes could read the 64th's marks on the steel ruler but I guess 32nd's will have to do.
It's a good alignment, car feels tight/solid/responsive.
It'll have to be done over when I poly the rear.
It went from 1/4 inch total toe in to 1/8 inch total toe in spread equal both sides. So I will leave it & put some more toe in at the event if I need it.
Thanks guys as always, you're the best.
I am all for easy & accurate.
Do the toe plates do thrust?
The nice thing about strings is as you set the toe on each corner the thrust is sort of automatically done.
Not to de-rail this, but can someone please explain the thrust angle? I have seen it mentioned several times and have not entirely understood it. When I set up a car I use parallel strings centered on the hubs, as above, so I can't understand why any sort of other measurement is needed once the toe is set correctly.
If setting up with strings, that won't happen. Also, in the front the worst that can happen when setting toe using a toe bar is the steering wheel will be off. In the rear, I can't see how one could screw it up. Can't imagine anyone setting up the rear using a toe bar.
Thrust alignment, if I understand it correctly, means that the front axle(s) have equal amounts of toe on each side, the rear axle(s) have the same, and if you drew lines parallel off the rim edges they would intersect the centerline of the car perfectly not missing the centerline off to the side of it.
Sort of a geometry explanation of it.
Link to alignment, scroll down to thrust angle
http://www.familycar.com/alignment.htm
I haven't seen it in a long time, but you used to be able to drive behind a car that had bad thrust alignment & it looked like it was "crabbing" down the road.
I use toe plates in the rear as well to set total toe. Using the electronic laser level you shine a laser towards the front of the car, just like a string, to make sure toe is equal on both sides and the thrust angle is correct. The David Farmer method is surprisingly easy.
