Does changing to SS brake pistons make a big difference?
I have the standard Z51 brakes on my car and I am wondering if changing to SS brake pistons would be a big improvement? Or is it worth saving my money and eventually investing in a brake upgrade?
I watched that yesterday and it looks very impressive...Looking to get imput from people that have some track experince with them. It looks like an easy (but very messy) upgrade.
The thermal conductivity - k - for some typical materials: .
Polypropylene PP - 0.12 W/mK
Stainless steel - 21 W/mK
Aluminum - 221 W/mK
Aluminum - 221 W/mK
Former Vendor
We have been using Stainless Pistons for almost 35 years in stock calipers. They are hard to beat in terms of reliability and robustness at the track.
Customers that have had issues with boiling brake fluid, melting inner seals and scoring with the aluminum pistons have found the SS pistons to be a worth while investment!
The C6 Z51 uses the C5 pistons.
Randy
Randy
Randy
Randy
My understanding is that thermal conductivity goes both ways. Takes longer to heat up but once hot, longer to cool down. Could there there be an issue with damaging/melting the seals from the cumulative effect of running HPDE say, half hour on and half hour off?
I'm considering the DRM "Short Stop" kit (SS lines, SS pistons & rebuild kit, brake ducts) with Quantum spindle ducts for my new C5 Z06. I'd buy the ducting and SS brake lines anyway but I don't have any previous experience with SS caliper pistons.
Before we could upgrade to bigger brakes in SCCA T1 class, we were allowed to change to SS on our stock calipers.
Huge difference and worth every penny.
Call Randy at DRM (Post above) thats where most of us bought ours and you cant beat the customer service.
Aaron
Aaron
A word of warning.
I got the DRM pistons for my Z06 and they were everything that has been said about them.
BUT the "Mod Monster" took over 1 month later and "made" me buy 6 piston Wilwoods!
Just say'in.
Just say'in.
35 yrs ago, does that mean Doug used them in the C-3 cast iron caliper? and did they work better than the GM J-56 insulated pistons?
Former Vendor
Randy
Former Vendor
I have video of the cool down also, but didn't want customers to sleep like high school economics vidoes
Randy
This is very true. The Stainless does take longer to cool down. We have been using them in HPDE type settings for a long time now. Not one problem with burning out seals earlier. I think having the piston is in the caliper-fluid and next to really hot things would even out the cool down.
Randy
Randy
I checked your site and see the pistons, but where do I get new seals/gaskets???
At the track a week ago I had a pad pin bolt back out (stock C6 Z06 calipers). A padlet fell out and the piston behind that one padlet extended out and ground down on the rotor (gouged the rotor as well!).
I need a set of your pistons, but I also need new seals.
Like johninar said, the mod bug may "make" me get some good aftermarket calipers, but for the meanwhile I want to rebuild my OE ones.
TIA,
Bob
