Quartermaster and P0300 (misfire) code
Old 06-07-2011, 11:16 PM
RX-Ben
RX-Ben's Avatar
Default Quartermaster and P0300 (misfire) code
Has anyone has this code result from a Quartermaster install or is it just coincidence and I should get serious about finding the origin?
The code pops up when idling, I thought the rattling discs/floaters might be causing it. But, this timing may correspond to the drive cycle timing for throwing codes.
Old 06-07-2011, 11:45 PM
sspeed30043
sspeed30043's Avatar
no mass to dampen the firing pulses, ecm thinks its misfiring
time to have misfire monitoring programmed out....
or bump up the idle.
But if you want to make sure hookup a scanner that can
do real time cylinder misfire and see if its just one or all.
Old 06-08-2011, 12:59 AM
mgarfias
mgarfias's Avatar
I concur about having the scanner drop cylinders to see if its really got a misfire. Otherwise... program it out.
Old 06-08-2011, 07:56 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I was told to remove knock sensors with solid mounts, but I never had a problem with underdrive aluminum pulleys or lightweight clutches causing false misfires. I expect it is a coincidence
Old 06-08-2011, 10:58 AM
John B
Pro Mechanic
John B's Avatar
In flywheel,rotating mass issues it can effect missfire calcs. I wouldn't program it out completely. Then you won't know if you develope a real problem. On cars with large cams , small torque converters, light or no flywheels, I typically can leave misfire calcs on over 2000rpms & shut off somewhere south of there depending on the animal.
Old 06-09-2011, 03:15 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Hey Ben,
I would put a Tech2 on it and see if it's the same cylinder or just random mis-fires. If it is in only one cylinder, I would check out that cylinder. (wire, spark plug, coil).
Old 06-09-2011, 04:24 PM
mphox
mphox's Avatar
I just installed a QM 7.25 triple disc clutch in my car. I have not had any misfire codes. May be a coincidence, but every car is a little different.
To Quartermaster and P0300 (misfire) code
Quick Reply: Quartermaster and P0300 (misfire) code
