C5 - wandering delrin front spring adjusters, popping sound
Old 06-13-2011, 11:11 AM
RX-Ben
RX-Ben's Avatar
Default C5 - wandering delrin front spring adjusters, popping sound
On a C5 w/the stock spring setup - has anyone noticed their spring adjuster bolts losing 1/4 turn after a few sessions? I am using Hardbar adjusters and noticed this.
I've also noticed a popping sound, many laps into a session (during a full throttle "turn" (a curved straight)), seemingly the same sound as the initial pop when the adjusters get seated, which occurs when I start driving after jacking up the car. Anyone experienced this and know what is happening?
Old 06-13-2011, 12:38 PM
froggy47
froggy47's Avatar
Old 06-13-2011, 02:05 PM
sperkins
sperkins's Avatar
Has this been verified by markings?
I've polished and lubed my lower arm where the adjuster rides to eliminate as much bind as possible and I've never had this problem.
Old 06-13-2011, 02:07 PM
geerookie
geerookie's Avatar
In addition to polishing the landing I also put a little wheel bearing grease on there when I ran that setup.
Old 06-13-2011, 03:27 PM
RX-Ben
RX-Ben's Avatar
I only noticed the adjuster bolt when I marked recently marked the bolt and saw it back off 1/4 turn from the initial setting
To C5 - wandering delrin front spring adjusters, popping sound
Quick Reply: C5 - wandering delrin front spring adjusters, popping sound
