Holding the engine up to remove sub frame?
Old 08-10-2011, 12:41 PM
froggy47
froggy47's Avatar
Default Holding the engine up to remove sub frame?
Best way? Tech needs to pull spring & sub frame to replace upper oil pan & from cover gaskets.
Is this an extremely critical procedure of is there some "leeway" if the engine moves an inch or so up/down?
What is the worst that can happen? Crack torque tube? Worse?
Thanks.
Old 08-11-2011, 10:49 AM
SPDYC6
SPDYC6's Avatar
Thanks.
I did this several years ago when I put the windage tray in the bottom of my oil pan. I built a small bridge across the overhead of the engine using 2, 12” long 4 X 4 resting on top of the shock mounts, then you use a 4 X 4 to each of the 12” to make a bridge. I have a small chain hoist, but if you don’t have that a good ratchet strap that you can get tight will work as well. Since the engine isn’t moving or swaying the bridge stayed in place the whole time that I did all this work.
Joe
Old 08-11-2011, 03:44 PM
Z11409
Z11409's Avatar
Do a seach for 'Engine Support Brace or Bridge' Even Harbor Freight tools has one for $60
Old 08-11-2011, 10:37 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
you might get enough room by lowering the subframe as far as it will go on the bolts, then jacking the engine as far as it will go on the engine mount bolts. That's several inches of travel, maybe "just enough".
Old 08-12-2011, 02:13 AM
froggy47
froggy47's Avatar
Thanks guys.
Old 08-12-2011, 08:53 AM
JDIllon
JDIllon's Avatar
Harbor Freight makes one that you may have to mod a little to work. Several people on the forum have used it. And it is pretty inexpensive. JD
To Holding the engine up to remove sub frame?
Quick Reply: Holding the engine up to remove sub frame?
