shredding inside rear wheels??
Old 08-15-2011, 04:48 PM
z16
z16's Avatar
Default shredding inside rear wheels??
Inside rear wheels appear to be shredding. Im guessing I need an alignment. If so, anyone in DFW AREA?? I took off z06 brake ducts to add a wider tire. I have 335 on temporarily on ccw classics, they are the original big street classic ccw used to sell. When tires are replaced will drop down to 315. I don't see them rubbing and was told by ccw they don't rub. thanks john
Old 08-15-2011, 04:50 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Check toe.
Old 08-16-2011, 12:32 PM
knyght4
knyght4's Avatar
With 305 30 19, I only rub when I hit a good bump, and I run with coilovers. If you are lowered on stock bolts and with a slightly aggressive alignment, you are going to rub a little with that size. 315 might be better, and not rub as much.
To shredding inside rear wheels??
Quick Reply: shredding inside rear wheels??
