At Rd Atl - Ps pump or rack?
During hard turns steering feels like wheel loose or ps is kicking in and out. Any way to check either? Feels OK in straight line. Anything to check before next session?
Had the exact same issue with my '03Z after boiling the ps fluid at Roebling. I would be steady state mid-corner and steering wheel would see-saw back and forth as power assist came in and out.
I replaced the pump, but it did not cure the problem. I'll replace the rack someday, but it doesn't happen on the street.
I replaced the pump, but it did not cure the problem. I'll replace the rack someday, but it doesn'thappen on the
street.
street.
Sperkins
street.
street.
Sperkins- that is what it feels like. So just live with it?
Kist finished session. Didn't do it as bad but you could feel it wanting to. I must have got ps fluid hot?
Tires r fresh R80 scrubs. Still
Only doing 1:45 laps- sad sad sad. Looking around for instructor.
Thanks for input !
Thanks for input !
Sorry I could not have been more help for the car ,when I had a chance to come over I didnt see anyone around. I would have gladly rode with you if I knew you were looking for some help. I got the red/white/blue vette down to a 1:31.
P. S. Issues too
This season I went from non run-flat street tires and have been using
R80 race slicks. Knowing my power steering issues would get worse I looked into: the Turn One pump, changing underdrive pulley and an off market heat exchanger. I chose installing the radiator for this and fortunately my P.S. reservoir has shown no overflow issues.
This change has worked for me.
I don't think mine was a fluid problem. I checked fluid level before I left and add just a little. Problem was 3rd lap into 2nd session and I didn't push that hard on first session, so I am not sure it was fluid. That being said, I did remove cap between sessions to help fluid cool. Hopefully it was just pump adj to R80s. IIRC from my engine swap, the ps pump doesn't come off easily.
I hate I missed the ride along. We were sitting in the press room(a/c) checking everyones times. We didn't time anyone faster than you. The Ferrari 458 was at 1:34ish, Supr was in the high 1:38s, the Miata yes, the Miata was in the low 1:30s etc. It would probably help me to be in the advanced class to learn some better lines. Hopefully next time.
I never had problems with C5 power steering pumps-my camaro LT1 would only last one event before you needed to replace the pump. Got a turn one, and never had a problem again.
Normally when a pump is going out, you will have power assist and then it goes out. Can make it interesting-losing it completely is not a big deal, but when it comes in and out it is hard to manage.
I would think a rack going out would leak a lot of fluid. Do you have a leak?
Tim
Tim
No leaks. At first I thought a wheel was coming loose or a bearing going bad, so I came straight in. No fluid coming out of ps resevoir all day. It started on 3rd lap of 2nd session, so I don't see how it could be fluid boiling. Is there like high temp ps fluid anyway?
Tim
Tim
