Possible aero balance issue?
Old 08-23-2011, 07:43 PM
jls288gto
jls288gto's Avatar
Default Possible aero balance issue?
I just installed the Glover rear diffuser on my C6, and wanted input before my next event (VIR full course). Think this will cause enough rear downforce to cause a balance issue at speed? I'm concerned about the uphill esses in particular. Any input would be appreciated!
Here is the rear diffuser on the car:
Old 08-23-2011, 08:06 PM
jlutherva
jlutherva's Avatar
Nice looking diffuser!
Did the vendor do any wind tunnel testing that indicates you are going to improve your rear down force?
My guess would be that you would not even notice any difference, but that's nothing more than a WAG.
Start at the same entry speed and see if you can feel any difference.
Will you be there with TrackDaze this week?
Jim
Old 08-23-2011, 08:32 PM
Rob Willis
Rob Willis's Avatar
Cool. I always kinda wanted one of those. Just didn't think they blended the ends/side of it well enough.
Let me know if it feels any different!
Old 08-23-2011, 09:12 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
how and where does it connect underneath? can air pack up inside of it?
Old 08-23-2011, 10:39 PM
RX-Ben
RX-Ben's Avatar
My understanding is that the center section for the exhaust really prohibits the setup from working well.
I doubt you will feel a difference (or at least nothing like running a wing w/o a splitter)
Old 08-23-2011, 10:40 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I don't think it will make a difference, but worse case it will keep the rear settled as you crest turn 8 (the yump). Understeer is rarely a bad think from a safety/balance standpoint.
Old 08-24-2011, 08:03 AM
andy3101
andy3101's Avatar
I run that same diffuser with MTI front splitter and MTI rear spoiler, and zr1 styled side skirts. I can't say I noticed any differance on the track compared to a car I drove with zr1 front splitter and rear spoiler with stock diffuser..
You might want to check all the screws in the diffuser.. I an issue with the screws falling out at the track last weekend. Ended up zip tying the the diffuser to the bracket in on the one side as a band aid..
Old 08-24-2011, 10:47 AM
redtopz
redtopz's Avatar
You probably won't notice any difference. I bolted an APR wing on the back of my C5Z which provides a lot of rear downforce and it was noticeable and resulted in decreased lap times (for a couple laps). For example at Thunderhill I went from mid 1:55's with no aero to mid 1:53's with the wing. After a few laps, the front tires started getting hot and the car pushed. More rear down-force will make the car easier to drive and more confidence inspiring, but if you start to push you will have to lift off the gas to get the front end to bite and turn in.
Old 08-24-2011, 02:22 PM
0MTI RACING
Former Vendor
MTI RACING's Avatar
I don't think it will make a difference.
I have seen that diffuser up close on a lift. It IS a nice cosmetic look.
Aero is a very, very scientific chain of events. One aero device affects another. You absolutely MUST go to the wind tunnel to verify what works, and why things don't work.
In order for a diffuser be effective, the diffuser airpath needs to start from at least from the middle of the car. Even then, the shape has a huge influence on the airflow path.
For example,
This is a diffuser that we made for our MTI Racing Track Package.
It is hardcore, but it helped us to cut a 1:54 laptime at VIR.
Grassroots Motorsports magazine upcoming Nov issue has a full writeup on the MTI Racing Track Package. It will be released on our website shortly.
Old 08-24-2011, 02:58 PM
RX-Ben
RX-Ben's Avatar
Which wing? No splitter?
Old 08-24-2011, 06:07 PM
redtopz
redtopz's Avatar
This one:
No front aero. It was basically a T1 car with a wing. It's not a bad setup for time trials, but no good for racing.
Old 08-24-2011, 06:25 PM
vette6aut0x
vette6aut0x's Avatar
For example,
Plus 750hp more than likely didn't hurt.
Old 08-24-2011, 07:31 PM
RX-Ben
RX-Ben's Avatar
Is that a GTC-300 or GTC-500? The 5 looks like it has a ton of downforce (vs the Kognition and the Fulcrum), though obviously more drag.
Is another 200hp and full aero really only worth ~3sec @ VIR vs a C6Z with bolt-ons (Todd's car)??
Old 08-24-2011, 08:01 PM
Falcon
Falcon's Avatar
FWIW the GTC-500 has 345# downforce at 120 mph with 64# drag.
The 72" Kognition has 423# downforce at 120 mph with 39# drag.
Old 08-24-2011, 08:12 PM
RX-Ben
RX-Ben's Avatar
Thanks for that correction. I prefer the Kognition mounting setup as well. And they have a picture of an awesome corvette, so I am totally sold!!
Are you running a 4" splitter?
Old 08-24-2011, 09:22 PM
Falcon
Falcon's Avatar
Mine is ~3", but it's extendable up to 5". But at that extended length, it makes loading and unloading a lot harder because it'll drag.
Old 08-25-2011, 03:30 PM
varkwso
varkwso's Avatar
Originally Posted by Falcon
Mine is ~3", but it's extendable .....
you sure about that
To Possible aero balance issue?
Quick Reply: Possible aero balance issue?
