Radiator fans on a track only car?
I have a 2000 C5 with an essentially stock LS1 that I use as a track only car. I am stripping it to save weight including the interior, A/C, etc.
I recently replaced the stock dual radiator fan unit with a single 10" fan. My thought is I should not need the fans on the track and the single small fan will help with overheating on the grid.
I haven’t taken it out in this configuration yet. I am now questioning if I did the right thing. Does the stock radiator really need the fans to keep the engine cool even at speed?
I searched the forum and found several references to no fans on aftermarket radiator but no examples of no fans on stock radiators.
Anyone here have experience with this?
Thanks,
John
Thanks,
John
CI 4-5-6-7 Veteran
I ran without and the car is fine on track, but you inevitably get hung up getting onto grid, off track, or even loading the car on the trailer. I put in a small 10" elec fan which I will be trying out for the first time next week. I can tell you it is not big enough to maintain temp at idle, but it definitely slows down the process. I'll let you know how it goes.
