1999 C5 T1 Corvette For Sale – Project Car
Old 09-04-2011, 02:53 PM
MattT1
1st Gear
MattT1's Avatar
Default 1999 C5 T1 Corvette For Sale – Project Car
Approximately 13k original miles
The car was originally built by Phoenix Performance and has been a race car all its life. I have been the owner of the car for the past five years although I only raced it for three seasons. When I purchased the car from Phoenix Performance they had just freshened the car with an all new drivetrain, exhaust system, and paint. Since then I've competed in about 6 Regionals and 16 National races.
The car sustained front-end damage at a National race in Buttonwillow, CA. The LF fender hit a tire barrier with the main impact point just in front of the LF tire. Both frame rails are bent just in front of the forward upper A-arm mount point. The radiator, one headlight assembly, and hood and are still good but the remaining bodywork needs to be replaced, along with new frame rails. I believe the engine cradle, suspension, and steering are ok, but I haven't inspected them thoroughly. I would replace the upper A-arms due to the proximity of where the frame rails bent. I have a lot of pictures showing the current condition of the car that I can share.
This is a standard Phoenix T1 build plus the following:
          Before Crash
          Side That Hit Tire Barrier
          The car is repairable and would make a good project for someone. I would prefer to see it back on the racetrack rather than get parted out.
          Asking $11,000 for everything
          Located in Phoenix, AZ
          Matt Humrick
          kepler_76@yahoo.com
          Old 09-04-2011, 03:27 PM
          fatbillybob
          fatbillybob's Avatar
          I emailed you matt. contact me if you did not get my email
          fatbillybob@yahoo.com
          Quick Reply: 1999 C5 T1 Corvette For Sale – Project Car
