Needed for Mid-O - 2 front wheel bearings
I got 2 wheel speed sensor codes this past weekend...LF open/short and RF excessive variation. If you are headed to Mid-Ohio and have or can pick up a couple wheel bearings, please let me know.
This is also the first weekend I ran extended sessions on A6s. Higher brake disc temps may have seeped into the bearings, due to the one-piece discs that I use.
Thanks.
Thanks.
Are you looking for new? Do you want SKF?
I have 2 or 3 original GM ones that are used but in good shape. You can have those.
I also have some SKF's but you will have to buy or replace those. They are brand new never been used.
Let me know. I'm leaving Tues. or Wed.
It depends on if I have to tow Rob's car there.
