Rebedding Brake Pads?
I didn't properly bed in my brake pads. Now I have a bad vibration when I break hard. Checked rotors, no cracks ,they look good.
What is the best way to rebed them? I Was going to sand the pads
And Schottch Brite the rotors. Then rebed them.
Thanks. Tris
Thanks. Tris
Can't speak to sanding, but this happened to me once when I had pad compounds that were not very compatible. After researching it I read that if you drive around and do some "cold" braking (normal street driving/braking) the friction will remove the uneven pad deposits that are causing the judder. I drove the car on some street trips and could feel it improving pretty quickly and in a short time the brakes had no vibration. When you reach that point I assume you could then try to re-bed your pads.
Thanks guys , i'v driven the car a about 200 miles on the street sence the last track day. I'll go and rebed the brakes when l get home Sunday.
Thanks agin Tris
Thanks agin Tris
I would like to add that I cannot believe anyone would spend the time to take sandpaper to their discs. It is so boring and take forever compared to murdering the brakes 8-10 times. Brake pads are abrasive and will clean off the deposits. You don't need to get the Hawk blues or whatever JRitt @ Essex recommends to get the job done (though I am sure they work well).
Also, I never bed pads, other than stabbing the brakes 5-6 times to get the pads up to temp on my out lap. I'll give a medium heat cycle to discs, to avoid heat shock (cripples rotor life in my experience, particularly with the cheap blanks). NASCAR teams spend some bucks for that heat cycle on a brake dyno and I think they are on to something.
I can see uneven deposits on the rotors that vibrate.
DH
