LS3 add on oil cooler
Old 09-21-2011, 12:09 PM
DRUGschnorr
Support Corvetteforum!
DRUGschnorr's Avatar
Default LS3 add on oil cooler
have a z51 w/ a Z06 oil cooler.. want to add another.. does anyone have an idea where i can tapp into the oiling system in the front of the engine? want to avoid the headers..
Tried the stock location and burned the hose after a spirited run on the streets.. glad it was not on the track... would have been very unpopular.
Old 09-21-2011, 01:24 PM
tomiboy
tomiboy's Avatar
How much did just the one Z06 cooler help?
Old 09-21-2011, 01:43 PM
davidfarmer
davidfarmer's Avatar
you can't just tap into the system, you must have a feed and return. There are feeds in the front of the engine (often used for accusump) but I don't know of a return. And you can't just dump it back into the pan somewhere, or you'll bleed off your pressure.
I think you just need to route your line better, often between the block and engine mounts will protect them from the heat
Old 09-21-2011, 03:53 PM
DRUGschnorr
otay got it i think... will report later..
1. adding the z06 cooler helps when the temps are normal.. but texas has been hotter than he** this summer.
going to get another stock steel tubing... remove the slip-in connector from the stock air cooler...run it into the radiator... use a new hose from rad to air cooler and leave return side alone... wish me luck
tried it last month w/ all steel hose and failed at the headers... just too close a fit..
Old 09-21-2011, 03:54 PM
DRUGschnorr
stock steel tubing is against the engine block below the motor mounts.. so Dave you are right again...
To LS3 add on oil cooler
Quick Reply: LS3 add on oil cooler
