How many of you have removed your Parking Brake?
Old 09-27-2011, 08:23 PM
JimbeauZ06
JimbeauZ06's Avatar
Default How many of you have removed your Parking Brake?
Just curious.
When I was helping a buddy strip his 944 for PCA SP2 we removed all of the parking brake hardware from the rear wheels. Of course we avoid using the parking brake at the track and he wanted to shave off every possible pound anyway.
I was thinking about this while trying to get that damn piece of "coat hanger" Chevy calls a spring back in and just about pulled it all off in a fit of frustration anyway.
So I'm probably one more event away from new rear rotors and was thinking about pulling it all off and adding to the junk pile.
Thoughts?
Old 09-27-2011, 08:37 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
add it to the pile
Old 09-27-2011, 09:30 PM
Aardwolf
Aardwolf's Avatar
Mine has been gone quite awhile.
Old 09-27-2011, 09:39 PM
sperkins
sperkins's Avatar
Originally Posted by Jason
add it to the pile
Pick up some light weight 2pc rear rotors while you're at it.
Old 09-27-2011, 09:53 PM
brkntrxn
brkntrxn's Avatar
No parking brake here. And I know of LOTS more the same way.
Old 09-27-2011, 10:07 PM
RX-Ben
RX-Ben's Avatar
gone. Didn't work anyway. 2 piece rotors do work.
remember that you cannot leave your car while it is running while on a incline. Who would ever do such a thing?
Old 09-27-2011, 10:14 PM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Mine is gone also. Thought about putting it back in one day then came to my senses!
Old 09-27-2011, 10:22 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
took mine all off,the day we put the front brakes ,on the rear
Johnny
Old 09-28-2011, 12:38 AM
dbratten
Support Corvetteforum!
dbratten's Avatar
Johnny
Yes, same here.
--Dan
Old 09-28-2011, 07:40 AM
AU N EGL
AU N EGL's Avatar
parking brake ?
Old 09-28-2011, 07:49 AM
Locke
Locke's Avatar
Default Barking Brake Delete
Back when Florida still had state inspection I removed the parking brake and all related hardware from my '69 and insalled a line lock in the rear brake line using the little switch on the parking brake handle for the line lock.
Put the brakes on, pull up the handle, release the foot brake just like the inspector wants to see looking in the window and let the clutch out (in third gear instead of first if you can get away with it), engine stalls and the inspector is happy
We no longer have state inspections, so my 'new' '69 has no parking brakes and the handle may disappear from the inside too. I just can't decide how much I want to mess with a custom interior.
Locke
Old 09-28-2011, 08:22 AM
geerookie
geerookie's Avatar
Are you drifting or road racing?
Old 09-28-2011, 08:53 AM
JimbeauZ06
JimbeauZ06's Avatar
Road racing mostly with the occasional drift thrown in for fun!
Ok, so junk it is.
Old 09-28-2011, 09:30 AM
drivinhard
drivinhard's Avatar
e-brake delete and 2 pc rear rotors is 7-8 lbs of weight savings EACH corner, that's huge. ~16 lbs of unsprung gone for $600 and rotors that will last way longer than OEM or Chinese pot metal ones, hard to beat it.
Old 09-28-2011, 09:50 AM
ScaryFast
ScaryFast's Avatar
You will need a parking brake, they sell custom racing ones at some specialty stores.
I got mine at a specialty racing shop called Home Depot. Look in the "construction and contractor" area. There will be a bin labelled "scrap pile", it's full of a really nice selection of parking brakes. I chose a treated 2x4, about 6 inches long.
It's tough to set it from in the cockpit, though.
Old 09-28-2011, 02:19 PM
0Vector Vette
Former Vendor
Vector Vette's Avatar
Once you decide to remove the parking brake, we make 2 piece rear rotors without the parking brake provision. We use Coleman Racing rotors and machine the aluminum hats ourselves. They are direct bolt in replacements, directional, correctly vented, no holes, 100% made in the USA, and are very lite. The C5 rears weigh less then 10 pounds! We have them for the C5/C6 base, C6 Z51, and C6 Z06.
Give us a call if interested or have any questions.
Robert Finlayson
Performance AFX Motorsports
815-254-2631
Old 09-28-2011, 02:22 PM
Everett Ogilvie
Everett Ogilvie's Avatar
THIS. Save a bunch of rotating and unsprung weight by going to hats that are aluminum in place of the steel e-brake style of hat.
To How many of you have removed your Parking Brake?
Quick Reply: How many of you have removed your Parking Brake?
