AiM SOLO DL
AiM SOLO DL
http://optimummotorsports.com/SOLO.html
Looks like $699 and it looks like it'll hook to OBDII and/or a SmartyCam and allow the AiM Race Studio 2 analysis software to look at all the data. A much cheaper entry cost than an AiM MXL Pista complete dash.
Another lap timer/data system to add to the mix... somebody needs to get one and let us know what it's like. :-)
What stinks (for me, with a c5) about systems that only have OBD2 hook-up is that 2 of the 3 most important non-G/GPS inputs (brake press, steering angle) are not sent over OBD2. This is where Race Technology loggers shine. And the software is great.
I don't get brake pressure out of my ODBII on the Pista. I do get steering angle. But honestly I haven't figured out how to make sense of it. The AiM MXL Pista is like the DL1 in that you can add whatever sensors you want on top of the OBDII data (or instead of).
The RS2 software from AiM was the easiest to use for me...
I got the regular Aim SOLO for $400. It is just as good for a training/teaching tool, just doesn't give you the sensor inputs. I also like having it while on track for the split times feature. Great product!
Do you really have to start predictive timing manually after a couple of laps by pressing a button? That's what I'm seeing on this video on youtube..... If so, that kinda sucks.
http://www.youtube.com/watch?v=eQCtBJ4knsA
I like the +/- because it lets me know how much faster/slower I am than my fastest lap. This is really helpful for me in Time Trialing.
Also, most tracks are already in the database and you don't need to set Start/Finish.
I just got one of the Solo DL and SmartyCam setups.
I used it for the first time this past Tuesday and I am working on understanding the Race Studio 2 software and experiencing a couple quirks with the video editing, although in raw form it is beautiful.
Oli
Oli
I thought the SmartyCam would do data logging, in that case you only need the ECU bridge rather than the SOLO DL, right? I guess that's unless you want the lap time display.
I've been staring at these video/DA systems for months now but have a really hard time figuring what components you need to do what with each vendor.
Last I knew SmartyCam would do data overlay, but AiM wasn't letting it export the .drk files directly for analysis in RaceStudio2. If that's changed that'd be great news. Otherwise the SOLO DL with SmartyCam is a very cost effective way to do things... about the same price as my MXL Pista was, but you get video with the display & data!
It likely only works on '06+ C6 cars... It connects to the (high-speed) CAN bus which isn't available on older cars, including 2005 if I understand correctly.
I tried several different cofigurations of set-up on the Solo DL to make it work with the C5 ODB2. I could not get any of them to report any meaningful data at all. Mostly the Solo DL picks up no information at all from the ECU. I have tried the Chevrolet Cobalt setting, the only one for Chevrolet. I have tried the GM C6 Corvette LS2 config and nothing. I have tried at the suggestion of the AiM distributor to use try the ODB2, CAN and ISO configs and still nothing.
Some of our local T1 racers have purchased the Solo DL, mainly for use with the SmartyCam systems. If we get any ODB2 data that will be a plus.
On that front, we have two SCCA T1 regional races and a national this coming weekend at Auto Club Speedway in southern California. Several of us are running AiM systems. The distributor, who happens to be about 30 minutes from the track, is coming out this weekend to provide some assistance and coaching. He is aware of the broad use of C5 in racing from coast to coast. He is going to install some "undistributed" C5 configs for us to try out. I have told him I don't need every parameter to work, but a few key ones would be nice. Hopefully next week I will have som more tangible news and successful results to post.
The C5 and '05 C6 do not have the "high-speed CAN bus" that gets used for the AiM products... '06+ C6 and other newer vehicles should work... I think the "C6 LS2" config also applies to LS3 and LS7 and LS9, FWIW. I don't know about the OBDII straight-up configuration... I had to wire the CAN+/CAN- pins to get my '06 to provide the data...
You won't be able to get data out of the C5, it's a SAE J1850 interface. Where as the 06+ C6 is a CAN Bus system.
I looked into all the different systems I could find and there were only 2 that would read stuff out of the C5. One of which I can't remember, the other was Race Chrono. Now if you Google RC, it comes up as a phone app...which it is. However, they make a kit for 699 that included a small stand along touch screen, high speed Bluetooth GPS receiver and a Bluetooth OBDII reader that will read and data collect from the SAE J1850 cars.
I got one of those and haven't really got to use it yet since the first time I tried to get lap data I had the course in the device set to uni directional and of all days to go out we were running in the opposite direction so nothing was recorded. Won't get a chance to get out till next month.
Even then at 699 for RC setup, you go get a GoPro for 299 and the RC comes with software that allows you to overlay the video.
Jay
Jay
Am I reading this correct? The aim solo DL will record rpm, steering angle, brake pressure, TPS from the ecu on a C5?
Or are you saying go with a different data logger system?
