Length of straightaways at Road America?
Old 10-20-2011, 03:58 PM
Everett Ogilvie
Everett Ogilvie's Avatar
Default Length of straightaways at Road America?
I once found this info online with a search, but can't seem to find it anywhere today. Anyone know the length of the front straight, and also the length of the straight leading to T5? I am interested in comparing them to the front straight at Miller which is supposed to be 3500', and apparently the longest straight in the US is at Spokane, 9/10 of a mile?
Old 10-20-2011, 04:13 PM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
Old 10-20-2011, 04:22 PM
Short-Throw
Here's a cleaner version:
http://www.roadamerica.com/userfiles...r%20Map(1).pdf
Old 10-20-2011, 04:24 PM
Everett Ogilvie
Thanks Buddy! Hmmm, so from the exit of the Carousel to the entrance of Canada Corner is ~ 4000' according to Google Earth. Guess that means one should be flat the whole way since they obviously consider it a "straight".
Old 10-20-2011, 04:30 PM
vette ruminator
vette ruminator's Avatar
Location: Deerfield, Illinois Turn On, Turn In, Track Out
Yeah but the whole "don't lift at the kink" business is too spooky for me... a tap on the brakes before getting back on the gas leaves me feeling better about having a car to drive home... U bringing the Mosler on a field trip Everett? That thing has enough power to turn back time on a track like RA.
Noel
Old 10-20-2011, 04:53 PM
AU N EGL
AU N EGL's Avatar
VIR front straight is 3000 feet
VIR back straight is 4000 feet
Road Atlanta from T7 to T10 is LONG and Very fast
Old 10-20-2011, 04:55 PM
Everett Ogilvie
OK, I just "measured" the length of the front straight with Google Earth - looks like it is ~ 4200'. (I did not include much if any of the corner radii in the distance measurement). Had never measured distance with GE until today.
And Noel, I will leave the no-lift in the Kink up to Mike....
Old 10-20-2011, 05:01 PM
AU N EGL
AU N EGL's Avatar
I went through the kink and never lifted. Not once
But then again it was only at 80 mph ( whistling )
Old 10-20-2011, 05:14 PM
Everett Ogilvie
Looks like it is 4300 - 4400' (Google Earth, my new friend!)
Old 10-20-2011, 09:04 PM
63Corvette
63Corvette's Avatar
Everett according to my RA Tee-shirt, the pit straight is 4405 feet long (uphill). That's 1380 to the Kohler bridge, and 3025 on to turn one.
Please NOTE that on-board video of NASCAR shows slightly HIGHER speeds on the slightly shorter downhill straight to turn 5. At the KIC, I noticed that all SANE competitors were braking BEFORE the first shutoff marker for turn 5. The "kink" and Canada are for you to decide
Old 10-20-2011, 09:14 PM
Lawdogg
Lawdogg's Avatar
Brainerd International is about 5000' on main straight. Known for years as the longest straight in North America followed by the fastest turn (22 degree banked sweeper).
Old 10-20-2011, 09:58 PM
MNCrystalRed2011
MNCrystalRed2011's Avatar
The banked sweeper (turn 1) is banked about the same as the tri-oval at Daytona.
Everett Ogilvie
Garrett - I too was braking before the 5 marker heading down into turn 5. That part of the track had the largest pucker factor for me and I was carrying some pretty big speed there for sure. I set my dash recall before each session and it indicated 158. I initially assumed that was on the front straight - now I am not so sure, it might have been on the straight heading into 5 instead.
Old 10-20-2011, 10:47 PM
dvandentop
dvandentop's Avatar
damn the kink looks extreme on the map mike posted.
yea get fastest speed on the straight into 5
also everett lets pack that mosler up and take it on one lap this year? think it has enough luggage space so we can alteast change underwear each day
Old 10-21-2011, 08:14 AM
AU N EGL
AU N EGL's Avatar
Fastest corner I have ever gone into was Charlotte motor speedway NASCAR Turn 3.
Think I went into that once at 150 mph Chit, that was scary. the straights are banked 18* and the turns are banked 28*. all you see in front of you is the asphalt of the turn. Too look DOWN the track you have to look UP near the A-piller of the windshield, or out the drives side window.
after doing that a few times, I have a LOT OF RESPECT for the NASCAR boyz who go through there THREE WIDE AT 180MPH.
Old 10-21-2011, 08:51 AM
Everett Ogilvie
That has to be quite an experience, getting on a banked oval.
Old 10-21-2011, 10:54 AM
Short-Throw
You sure you're not looking at the chicane they use for motorcycles?
To Length of straightaways at Road America?
Quick Reply: Length of straightaways at Road America?
