stock c5 z06 on hoosier driven hard on track leaking various fluids
Old 10-23-2011, 05:22 PM
2MCHPWR
2MCHPWR's Avatar
Default test thread
test post
Old 10-23-2011, 08:57 PM
stevensa
stevensa's Avatar
Check your air filter, it may be soaked with oil from your intake and is now dripping out of the airbox.
Old 10-23-2011, 10:53 PM
CHJ In Virginia
CHJ In Virginia's Avatar
1) On your oil, disconnect the coupler on the throttle body and see if any oil is present. You might want to consider one of the catch cans. 2) Check the PS fluid and see if it is murky rather than clear. If so, you are going to need a new pump as the internals of yours are taking a dump. The stockers will eventually die. I replaced mine with a Turn One and flushed the system. No problems since. 3) The MC cap gasket will get hard and leak. I replaced mine with a NAPA replacemnet and no more drips.
Old 10-24-2011, 12:32 AM
TRACKMAN2
TRACKMAN2's Avatar
[QUOTE Could oil be in there? How else could the oil go to the front of the car? where you behind my c4?
To stock c5 z06 on hoosier driven hard on track leaking various fluids
Quick Reply: stock c5 z06 on hoosier driven hard on track leaking various fluids
