Leaking Axle Seal, GM Seals OK for Track?
Old 11-06-2011, 06:09 PM
n8dogg
Support Corvetteforum!
n8dogg's Avatar
Default Leaking Axle Seal, GM Seals OK for Track?
Hey all, just wondering if the track guys have a better solution than replacing leaking axle seals with the GM seals. I know they are an updated PN, but still seem to leak. Thanks.
Old 11-07-2011, 12:49 AM
RX-Ben
RX-Ben's Avatar
Not that I know of. My replacement did not leak. You may also have a puking breather as opposed to a leaky seal (which is what I had).
Old 11-07-2011, 11:15 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
I've come across this several times, typically it's a groove that's worn into the 1/2 shaft itself - I buy used 1/2 shafts for $125 - $150 and swap it out with a new side seal - so far I've fixed 4 cars by doing both.
To Leaking Axle Seal, GM Seals OK for Track?
Quick Reply: Leaking Axle Seal, GM Seals OK for Track?
