Clutch fluid
Old 11-08-2011, 02:45 PM
MYRX
MYRX's Avatar
Default Clutch fluid
Getting ready for a TT session at RD Atl in Dec. I was thinking about changing my clutch fluid, (hasn't been changed since I have owned the car and only has 14K). Still it is a 2002Z and likely needs it. I was wondering if there is a brand most prefer doing track days. I was thinking I saw that GM recommends DOT4, but wondered if like brake fluid, most of you upgrade to another type.
Old 11-08-2011, 03:42 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Blue or Gold brake fluid.
Old 11-08-2011, 04:57 PM
spdislife
spdislife's Avatar
Motul 600 here
Old 11-08-2011, 05:08 PM
froggy47
froggy47's Avatar
Wilwood 570 or Ferodo (570+)
Old 11-08-2011, 06:05 PM
gmccreary
gmccreary's Avatar
I use ATE Super Blue or the gold stuff. What class are you going to run?
Old 11-08-2011, 06:17 PM
MYRX
MYRX's Avatar
Looks like you all use the brake fluid you are using for your calipers, correct? So, guess I will use my Castrol unless you guys know better. So what happens if some of it gets mixed?
I am running TTS. Since August I installed new springs, shocks, adjustable end links, etc. Jeff England convinced me to contribute to his tire collection since Scott and Mark have enough. Seriously, I like the idea of being able to pick and choose my suspension set-up. Just hope I come into some extra $$ soon. Us older guys need all the edge we can get.
Old 11-08-2011, 07:05 PM
varkwso
varkwso's Avatar
TT$ you cannot hide money...
I use valvoline synthetic.
Old 11-08-2011, 07:09 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
Seriously. That should be the official decal for NASA required on the cars for TT$, $T2 and $T1
Old 11-08-2011, 07:17 PM
MYRX
MYRX's Avatar
I heard "if you build it, $$ will come". Isn't that true!
Old 11-08-2011, 07:19 PM
mfquinn
mfquinn's Avatar
Motul 600 here
Old 11-08-2011, 07:49 PM
travisnd
travisnd's Avatar
ATE Superblue for me. Changing it is a royal PITA unless you have installed an aftermarket remote bleeder line. Personally, I just suck it out of the reservoir and re-fill periodically. Whenever I install a new clutch or service the driveline I will install the remote bleeder.
Old 11-08-2011, 08:30 PM
sothpaw2
sothpaw2's Avatar
I use the Castrol SRF. Even from a container I opened last year (this is for clutch only now), it's still better than fresh Motul.
Old 11-08-2011, 10:21 PM
RaleighSS
RaleighSS's Avatar
I think most of us use what ever we use in our brake systems. For me it is ATE super blue when ya get your clutch done be sure to put in a remote bleeder ... makes bleeding possible. SRF is an overkill for the clutch but may be most simple since you are doing brakes at same time.....
Old 11-09-2011, 06:17 AM
varkwso
varkwso's Avatar
I heard "if you build it, $$ will go". Isn't that true!
Fixed it for you. I like the class for what you can do.
Old 11-09-2011, 08:15 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Amsoil DOT4 for brakes and clutch here!
Old 11-09-2011, 12:44 PM
waddisme
waddisme's Avatar
ATE Super Blue because I already have it. Only flush once a year.
Old 11-09-2011, 09:23 PM
JeremyGSU
JeremyGSU's Avatar
I use Prestone DOT 4 brake fluid.
Old 11-09-2011, 10:24 PM
Gman57
Gman57's Avatar
Left-over SRF and I clear the resivor after each weekend
Old 11-11-2011, 11:22 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
AMSOIL Series 600 DOT 4 Racing Brake Fluid (Product Code BF4SN)
Dry Boiling Point - 580F, Wet Boiling Point - 410F
For both my clutch and brakes for many years now.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
To Clutch fluid
Quick Reply: Clutch fluid
