Oil leak thru hose end - hot to fix?
Old 11-12-2011, 11:29 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Default Oil leak thru hose end - hot to fix?
-10an 90* swivel hose end is leaking oil. Can hose end be removed and reinstalled? Should I cut off the end of the braided steel hose before installling? Have a track day Monday, so I need some options. I have another hose end, but it is a female, but I could try to find an adapter, so I have that option. Suggestions?
Old 11-12-2011, 11:47 PM
trackboss
trackboss's Avatar
If you are sure it is leaking at the hose and not the fitting anywhere then yes. Cut end of hose and start over fresh. Don't over tighten when re-assembling hose end on.
Old 11-13-2011, 06:32 PM
waddisme
waddisme's Avatar
Whew!!! Repl just the swivel fitting and all is good. Did not want to take hose off and cut. Off to VIR tomorrow. Hopefully I can put the new T1 bars to good use.
Old 11-13-2011, 11:14 PM
mgarfias
mgarfias's Avatar
Did you test it under pressure or at idle?
Old 11-13-2011, 11:34 PM
waddisme
waddisme's Avatar
Took it for a quick spin- run it ip 4k rpms even though I already
Had slicks on
To Oil leak thru hose end - hot to fix?
Quick Reply: Oil leak thru hose end - hot to fix?
