Amperage draw for factory fans...
Old 11-17-2011, 01:06 PM
Falcon
Falcon's Avatar
Default Amperage draw for factory fans...
Anyone know what one of the factory radiator fans draws?
I just bough a 16" Spal fan and it draws ~18 amps, will the factory wiring/fuse for the fan handle that?
Old 11-17-2011, 02:50 PM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
The factory fans use relays and 30 amp fuses- should handle that fan just fine, If my memory serves me well I think the factory fans pull around 16-18 each once they are running
Old 11-19-2011, 10:50 AM
davidfarmer
davidfarmer's Avatar
grab an amp meter and measure one for us.
To Amperage draw for factory fans...
Quick Reply: Amperage draw for factory fans...
