C5 Stock Replacement Front Two Piece Rotors?
Who makes the best ones and why? The ones I am interested in are a replacement for the c5 front stock rotor using C5/6 calipers.
I'm using the Stoptech Aero 2 piece rotors because when you figure in the replacement ring costs they end up a little cheaper over time than some of the others. They've been working well.
Here's the original set after a 9 track weekends (was test fitting the Wilwoods). They're my backups now.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Ooops, sorry buddy. I missed the 'why?' in your OP. The AP have more and closer spacing on crossbridges to keep warping/expansion dips to minimum. I have not experienced any knock back with the wilwood SL6's (no anti-knock back springs). They are a little pricey - $1K for front set only and replacement rotors around $250 each. However, no down time working up a sweat in July while changing cracked rotor.
Tolero Apto Victum
I have a set of these on my C6 and like them a lot. They are lite and lasted a long time for me. http://shop.performanceafx.com/C5-Corvette_c13.htm
Location: If you don't weigh in you don't wrestle Road America
We've had very good results with StopTech rotors, between $650-$700 for the initial purchase and $140 - $150 for replacement rings.
Heck we got lucky and found a used set of rotors and hats for $300 a few years ago. It's nice to have spares
Looks like they run from ~$320 to ~$1000. I have seen the Stoptechs, AFX, DBA, Hardbar and Wilwood all on track and in the paddock. Cracking seems to be way less common (as it should be!).
You are definatly going to want to find out what the replacement rotor costs are going to be up front. Also see how difficult/easy it is for you to get replacement rotors - if there is a vendor in your area or if you have to order them yourself. Some of the stuff coming from Cali can take a week for you to get.
