Anyone make a Delrin swaybar mount?
Old 12-06-2011, 12:17 PM
travisnd
travisnd's Avatar
Default Anyone make a Delrin swaybar mount?
In light of the new NASA rules on the 255 tire I may end up going back to stock sways. Anyone make a delrin bar mount so I can make them as stiff as possible?
Old 12-06-2011, 01:29 PM
RX-Ben
RX-Ben's Avatar
I have not found any. Might be worth it to have a machine shop make a few sets of 2 piece blocks for the F/R. The brown delrin is best (the stuff the Phoenix uses - I think it is glass impregnanted).
I'm in.
Old 12-06-2011, 01:47 PM
tshirttom
tshirttom's Avatar
Default Delwin bushing
I'm in too if someone finds a source.
Old 12-06-2011, 08:03 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
http://www.emachineshop.com/ probably pricey, but do your own.
Can you modify the bars in any way to stiffen them.....ie drill new holes closer to the bars centerline? Or run really long/short heims to make the angle as tight as possible...90deg is the softest.
Old 12-07-2011, 12:03 AM
NVR2L8
NVR2L8's Avatar
Call Jerry Onks at Vettesport. 615-218-2823
email: jerry@vettesport.net He is located near Nashville, TN.
Old 12-07-2011, 11:47 AM
RX-Ben
RX-Ben's Avatar
No mods to the bars or links are allowed w/o points penalty.
Old 12-07-2011, 01:39 PM
davidfarmer
so if you run stock bars, you must run stock end links, which means you can't accurately corner balance....... awesome
Old 12-07-2011, 01:46 PM
travisnd
travisnd's Avatar
Super awesome... we've asked for them to make adjustable endlinks a no-points mod for 2012, but haven't gotten the official word on all the changes. We do know that the Hoosier 255/35/18 A6 is being treated the same as the 275 so I lose 6 mod ponits
To Anyone make a Delrin swaybar mount?
Quick Reply: Anyone make a Delrin swaybar mount?
