changing shocks....do I need an alignment?
Old 12-10-2011, 10:24 AM
Alludc
Alludc's Avatar
Default changing shocks....do I need an alignment?
swapping in the c6z06 shocks today. will I need to redo my alignment?
Old 12-10-2011, 11:00 AM
sothpaw2
sothpaw2's Avatar
No--should be fine if you don't adjust the ride height at all.
Old 12-10-2011, 03:48 PM
froggy47
froggy47's Avatar
If you loosen a control arm, make sure it goes back the same (shims or eccentric bolt, or whatever your setup is).
Old 12-10-2011, 04:40 PM
gkmccready
gkmccready's Avatar
I think you may find ride height will change whether you intend it or not. Different shocks often have different "head pressure" which results in a ride height (and therefor alignment) change.
When I installed KONI 3013Sports in place of my stock C6Z51 shocks ride height changed measurably (even after settling).
glen
Old 12-10-2011, 09:42 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
While I doubt your ride height will change significantly, measuring it before and after would not be a bad idea. At most, you might want to tweak your Toe.
Old 12-12-2011, 06:42 PM
Pfadt Racing
Pfadt Racing's Avatar
While it might not be absolutely necessary for an alignment after a shock swap, it's not a bad idea to check after finishing the install. An alignment is a whole lot cheaper than replacing an aggressive street tire or losing 2 track days on a set of race tires...
We would recommend it.
To changing shocks....do I need an alignment?
Quick Reply: changing shocks....do I need an alignment?
