Valve stems for ccw
Old 01-15-2012, 03:51 PM
froggy47
froggy47's Avatar
Default Valve stems for ccw
Got some used ccw with metal valve stems, valve core appears to be standard.
These have a rubber grommet inside to mount the stem.
I assume these metal valve stems do NOT have to be replaced every time like rubber usually is.
They appear in good shape, seller said rims are about 3 yrs old.
I would like to replace the grommet, where do you get these?
Is it a standard size available at most tire stores?
What do you torque it to?
Thanks guys.
Quick Reply: Valve stems for ccw
