Turn One pump c5 z06 users
Old 01-20-2012, 12:30 PM
2MCHPWR
2MCHPWR's Avatar
Default Turn One pump c5 z06 users
hi - i will get this over the winter for my street/track car.
Are you guys juts running the stock PS cooler?
Should I put another one in or is the stock one sufficient?
thanks!
Old 01-20-2012, 12:36 PM
travisnd
travisnd's Avatar
The stock one that came on the Z06 and Z-51 equipped coupes/verts is fine. Run a good synthetic fluid ( I run Redline) and swap out what's in the reservoir every few events. Having an underdrive pulley helps with accessory life as well (turns the pump a bit slower). I have an ATI Superdamper 10% underdrive on my car.
Old 01-20-2012, 01:02 PM
C5ZEE06
C5ZEE06's Avatar
With the turn-one, the oe cooler should be adequate..at least mine is. Ive been using Joe Gibbs psf lately.
Old 01-20-2012, 01:48 PM
johninar
johninar's Avatar
Turn one and a 25% underdrive. No need for additional cooler for me.
Old 01-20-2012, 04:13 PM
mgarfias
mgarfias's Avatar
I've got my turn1 pump on the shelf waiting to go in. They recommended Gibb's fluid for it.
Old 01-20-2012, 04:28 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
subscribed
Old 01-20-2012, 07:37 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I run the Turn One pump with the standard cooler using Joe Gibbs synthetic fluid as recommended by T1. Ran all last year including two events with ambient temps above 100 deg. No problems at all, never overheated or boiled the fluid. Change fluid annuually when I do the tranny and diff.
Old 01-21-2012, 10:32 AM
NemesisC5
NemesisC5's Avatar
If any of you drive your car both on the track and on the street occasionally, do you notice a difference in the steering wheel being harder to turn when parking or at idle? I've heard the Turn One units pump a lower volume of fluid.
Old 01-21-2012, 11:31 AM
MySR71
MySR71's Avatar
I have one of their track oriented pumps on my C5Z06 and yes, steering effort did go up, particularly at low RPM.
Old 01-21-2012, 01:33 PM
johninar
johninar's Avatar
Since I added the under drive at the same time, I can't relate what the pump alone offers. I suspect it's the same. The pump is made using the same housing as OEM. The big difference was the pulley. It was somewhat noticeable when I first got it, but I don't even notice it any more. A slightly higher effort required as a DD, but really not an issue for me.
YMMV,
John
Old 01-21-2012, 02:49 PM
naschmitz
naschmitz's Avatar
Same here with my C6. It is certainly something that you can live with, even on a DD.
Old 01-21-2012, 05:45 PM
hamdog
hamdog's Avatar
I bought the T-One pump (as I recall the higher pressure pump)four years ago for my '98 coupe with no cooler. The steering feel didn't change and after 40 + days AX and RR, I've had zero issues. Big believer in this product.
I've been running 285 Hoosiers in the front.
Old 01-21-2012, 08:26 PM
NemesisC5
NemesisC5's Avatar
YMMV,
John
Thanks guys for answering my question
Old 01-22-2012, 11:25 AM
kmagvette
kmagvette's Avatar
Scott,
Tell the guys at Turn1 that you want the low volume pump. When I called they tried to talk me out of it because of reduced assistance at parking space speeds. You will only notice it if you are in the habit of cranking the wheel real fast when the car is stopped or barely moving. The low volume pump will reduce temps all by itself. Running Pirelli slicks at Watkins Glen (still waiting for your Trackmasters visit ) I no longer have any PS issues. I did my pump 3 years ago.
Old 01-22-2012, 01:35 PM
Pumba
Pumba's Avatar
Thanks what I did with mine.
Old 01-24-2012, 08:02 PM
2MCHPWR
2MCHPWR's Avatar
Hi Keith - good info. thanks for the advise.
haven't been to a track other than monticello in over 3 years! But I plan to hit a few others this year with NASA TT.
Old 01-30-2012, 11:48 AM
2MCHPWR
2MCHPWR's Avatar
ordered thanks again guys.
To Turn One pump c5 z06 users
Old 01-30-2012, 02:43 PM
LEAVINU
LEAVINU's Avatar
What's the fluid capacity of the OEM system? Looking to swap to Redline fluid first then if still boiling move to the T1 pump.
What's the best way to remove all of the OEM fluid from a C6?
Old 01-30-2012, 02:47 PM
mgarfias
mgarfias's Avatar
T1 sold me 2 quarts of Gibbs fluid to go with the pump. Disconnect the return line with the car in the air, and turn the wheel side to side until no more fluid comes out. Reattach line and refill.
Old 01-30-2012, 03:11 PM
travisnd
travisnd's Avatar
Which one is the return line? I've always just sucked it out of the reservior with a turkey baster? Car on or off while turning the wheel? I assume off so you don't burn up the PS pump?
Quick Reply: Turn One pump c5 z06 users
