Selective ride Yes or No?
Trading 08 Z51 coupe next week for Grand Sport, have two to choose from, one with and one without.
I had this option on a 01 vert, wasn't into autox or HPDE then so I didn't use it.
Thanks in advance for the good info!
If you are gonna do a lot of DE stuff you might consider without. Save money and eventually do an upgrade. Better shocks or a full coilver. If mostly on streets with crappy roads MSRC.
I had pfadt coil over on my z06 and MSCR on the ZR. The coil over is much more precise and confidence inspiring in turns with unstable surfaces.
Joe
Joe
If you ever gave serious thought to upgrading your suspension it's easier to modify a Non Mag Ride vehicle. Also keep in mind that the Mag Ride shocks are extremely expensive to replace, to the tune of about 500 bucks USD per shock though GM Parts House...
If you want to stay bone stock forever, the Mag ride system may be worth taking a look at. If you ever want to make changes, it's easier without the mag ride.
