Tunnel Plate. Worth the investment?
Old 01-28-2012, 10:34 PM
JTRANTHA
JTRANTHA's Avatar
Default Tunnel Plate. Worth the investment?
I have an 06 C6 and wondering if a tunnel plate is a good mod for my car... any thoughts??
Old 01-28-2012, 10:44 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
you could spend money better. It will help with heat.
Old 01-28-2012, 11:10 PM
el es tu
el es tu's Avatar
Unless you feel like you need to stiffen the car up, the funds can be better utilized elsewhere
Old 01-28-2012, 11:36 PM
froggy47
froggy47's Avatar
Save your money or cut a piece of alum sheet yourself, line it with a heat barrier and save $$$$$
Old 01-29-2012, 10:38 AM
6SPEEDZ
6SPEEDZ's Avatar
The C6 has a better tunnel closeout than the C5 to start with. The c6 has a aluminum plate versus a stamped piece of sheet metal on the C5. So the gain in rigidity on a C6 is far less than it would be on the C5.
To Tunnel Plate. Worth the investment?
Quick Reply: Tunnel Plate. Worth the investment?
