Stock leafs and weather
Old 02-02-2012, 11:30 AM
gkmccready
gkmccready's Avatar
Default Stock leafs and weather
My stock leafs have spent a bunch of time outside leaning against my garage in direct sunlight. Are they still okay, or should they just get discarded now? They *look* fine...
Old 02-02-2012, 02:00 PM
RX-Ben
RX-Ben's Avatar
If they are Z06 springs, send them to me, I will test them for a year on the track and let you know.
My guess is that as long as temps were ok (not near the exhaust for the dyno that is surely in the garage?), you should be ok.
Old 02-02-2012, 02:13 PM
travisnd
travisnd's Avatar
I've heard that exposure to certain chemicals and direct heat (i.e. open exhaust dumps) are what can kill them (delaminate). Never heard anything about UV exposure hurting them. Many thousands of Corvettes are driven on the street in freezing weather and on a hot summer day I'm sure the spring sees way more heat than leaned up against your garage.
Old 02-05-2012, 09:47 AM
JVetthead
JVetthead's Avatar
they are painted so uv should not affect them
To Stock leafs and weather
Quick Reply: Stock leafs and weather
