Hawk Pad Question
Old 02-18-2012, 07:09 PM
C5Natie
C5Natie's Avatar
Default Hawk Pad Question
Hey guys, right now I have Hawk HPS pads on the car. Theyve seen mostly street duty and have been great. I even had them on the car when I did top speed runs at a dry lake, stopping the car from 190 and 200mph without issues. Thing is Im looking at some HPDE's coming up and was wondering if it would be worth swapping the HPS pads to some HP+ pads I have sitting around. Would the HP+ pads perform better at the track then the HPS pads? Also, do I need to clean the rotors if swapping from HPS to HP+? I dont know how different the two compounds are. Thnx
Old 02-18-2012, 10:12 PM
trapp
trapp's Avatar
I have run both of them and the HP plus are better for the track...
Daily driving the HP plus can get annoying...They handle the heat better in 15-20 minute sessions and you can stop quicker with the HP plus pads..
Old 02-19-2012, 10:27 AM
JimbeauZ06
JimbeauZ06's Avatar
HP+ is definitely better for DE. I don't know that it makes that big a difference but if it was me I'd just swap out rotors too when you do th e pads. You can get a set of Centrics from Tire Rack for less than $50 a wheel for fronts and less than $40 for rears.
To Hawk Pad Question
Quick Reply: Hawk Pad Question
