C5 Control Arm question(s)
So after a few seasons of autocrossing my C5Z, I've noticed that the lower control arms are pushing thru the bushings and are almost touching the mount. The Upper arms seem to be good so far.
I run in SCCA Stock class so I can't go anything custom or 'aftermarket' like any upgrades.
Can you just replace the bushings on them? I thought I read a while back that you could rebuild one of them, but couldn't remember if it was the upper or lower.
If so, any recommendations on where to get them and not get raked over the coals? If not, then I'll just have to pick up a couple.
TIA
TIA
Like I said, I cannot use those upgraded bit in Stock class, so I need OEM Style.
So, you're saying the lower control arms can be rebuilt?
Thanks, that's allot to pour thru. I did search earlier, but never got results.
I did not want to buy new control arms and have the same problem with the bushing walking out. I pressed out the bushing that was moving and reinstalled it backwards. Now it has a lip to push against to keep it in place. I did this two years ago and have had no problems.
Here is a link to the step by step as to how to do it so that it all bolts up again...
http://forums.corvetteforum.com/1570853571-post18.html
