Traqmate Question
Traqmate Question
At CMP last weekend, my Traqmate shows my lap times 9 to 10 seconds faster than they were. Any ideas what caused this and how I fix it?
I don't know how that could possibly happen with the GPS....
Except for one thing!!
You can see on the track map that the green flag (start line) and the red flag (finish line) are in the exact same place - and in the screenshot above the blue dot indicating the position of the car is going right across the s/f line.
So....the only thing I could think is that maybe your s/f lines are not in the same place. Check the track map on TraqStudio to make sure the green/red flags are in the same place, and if not change the coordinates of them so they are both the same.
Other than that, I dunno!?!?
Bob
Mo - depending on your antenna location TQ can lose signal. It then just tries to fill in the gaps so you get crazy lap times. Look at your speeds and see if they are off in any given segment.
All is good. I am not sure what it was. I had the display plugged into the PC by the USB cord, and I was viewing the sessions on the display. I downloaded the sessions onto the PC and they are fine when I view them with the Traqmate software. After unplugging the display and plugging it back in, the lap times on the display match those downloaded to the PC.
Strange.....
Strange.....
