EOC / TOC radiator for tranny and differential?
Wanting to cool down my tranny & differential, so need opinions here.
I have been tracking my 08 C6 manual for 4 years now. 3 yrs ago, I installed an C6 Z06 oil cooler in front of my radiator and saw my oil temps drop from 315 F to 270 F. I then hooked up an Accusump, locating the solenoid and pressure switch in the left rear wheel well. I now want to cool both my tranny and differential but do not have room to do both in the back. Plus air flow is limited in the rear. I am now thinking about buying a Dewitts or Ron Davis radiator with both engine oil cooling and tranny oil cooling capabilities. Couldnt I pump both the manual tranny fluid and differential fluid forward into this radiator? I know the viscosity of the differential may be pretty thick, so I may have to either install a temp. controlled valve or install a valve that I could toggle open once this fluid is warm enough to flow.
Has anyone used a good race radiator with both EOC and TOC for the transmission and differential?
You might speak to the folks at Doug Rippe Motorsports (DRM) for your specific application (no room on one side). A lot of Forum members use their cooling systems for the diff and trans, including me. The location of the heat exchanger is not important; you don't need airflow for a stock powered car, you just need to get the hot fluid out of the case and into a heat exhanger. BTW, wrapping the exhaust pipes, and trying various types of high end synthetic fluid didn't do squat to fix my overheating problems.
